unify curvature graph for surface edge and sketchs
both should at least be accessible by the same way:
https://drive.google.com/file/d/0Byzv_NlyKp_2cnMtbjBZTTZicTg/edit?usp=sharing
5 Comments
colin.smith
Claas, the link you provided doesn't work.  Can you explain what you are asking for or reestablish the link?
Colin
cekuhnen
Hi there
So you can show the curvature graph for surface edges through the inspect.
But that does not work for curves in sketches. there you need to turn on the curvature graph and I find that not ideal.
One tool icon should work for both objects and sketches.
colin.smith
Okay, that makes sense. Thanks for clarifying.
Colin Smith | Product Manager | Autodesk Canada Co.
M. 647-203-2590 | T. 905-582-7396
[cid:[email protected]]
colin.smith
I agree, this feature should work on curves as well as surface edges.  I'll bring it up with the modeling team.
cekuhnen
great
I think this will fit better the UI concept of less icons to click - an area Fusion is really good at sofar!
