A basic UI request. Put the last/next command after Undo/Redo in the Edit menu.
If one hits the undo command more than once it would be nice to be able to look under the Edit menu and see Undo: Line, or Redo: Insert into Current Design or whatever the last/next commands are... This saves one from hitting the keys multiple times to see if you undid or redid what you think you did....
