Undo on parameter change on solids not abort of operation
If I'm modifying solid, saying doing a push/pull and chaning + angle and press cmd+z for undo, I don't want it to abort the whole push/pull, just undo the last modification. This works as expected when working with t-splines, but with solids it just aborts everything.
Not only would this improve usability, but it would create a much more consistent behavior of the program.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
