Quick fillet of edges
I often as a finishing step want to do a fillet on all the edges of a solid, to remove sharpness of the designs I do.
I've reported a bug that the selection filter -> body edges only doesn't work anymore since a few releases.
This got me thinking, I should be able to select one or several bodies, and if I do a fillet with this selection it should apply it to all the edges of these bodies.
This should work for the chamfer as well.
3 Comments
Yes please!  This is the method I am use to having come from 20 years of using another program and really miss it.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
