Torch/Plasma cutting edge start
When cutting inch+ plate I prefer to edge start rather than pierce. It would be great to be able to select an Edge Start option that would automatically find the nearest edge and/or pre-drilled start. It would be ideal if entry points could be defined with a corresponding torch start point.
At present I've been working around the issue by defining an entry point and lead-in distance but this requires each path to be setup separately.
