Tool Orientation as a Folder Option
Currently if I have a bunch of operations to run at a tilted axis I use the Tool Orientation setting and place all those operations in a folder to override the Fixture #.
Which is fine. I use create derived operation to avoid setting up the tool orientation over and over again. But, I occasionally have to go adjust what angle the operations run at. Which when you have 20+ operations, require you go to into each and every operation and re-select references and becomes very time consuming for such a simple task.
Since I can already right click a folder and override my workoffset, why not let me set a "master tool orientation" for all operations in that folder?  Then we would not need to worry about all that extra work and it would speed up my life and I'd be super happy. I'll slip you a twenty if you can make this happen for me.
We do a lot of 5-axis work and this is one of my least favorite things about doing 5-axis in fusion.
