High light unconstrained elements upon request
I do like the program, I'm glad that I found it, and want to learn more. . .
Although a reasonably fluent Sketchup user, I'm a rank beginner on Fusion 360.  My first model attempt resulted in 1 of 3 sketches not being fully constrained, and I could not identify the problem.  When I posted to the forum, others replied that the sketch was all black and, thus, should be fully constrained.  My take away is that the existing convert-to-black-to-show-a-constrained-item is not fully successful.
The software must have some metric that identifies an element as un-constrained.  It would add value if, when faced with not identifying why a sketch is not fully constrained, I could have the program highlight, box in, flash or do something to show me the issue.  Detroit provides idiot lights for drivers; you guys are smarter, so why can't you provide an idiot notice to your users?
Very respectfully,
Larry
2 Comments
Noah_Katz
Good idea.
Even better would be the ability to animate the degrees of freedom to avoid having to try different constraint types
s.david.baxter
This is an excellent idea, I was about to post an idea to create a counter that indicates how many unconstrained pieces of geometry still exist in a sketch however this would still require the user to hunt them down and in a complex sketch this can be problematic.  Your suggestion is elegant,  I hope AD returns focus to the user interface part of Sketching sometime soon, after all it pretty much the building block of the whole concept.
