tool inspection machine stops
there needs to be the ability to create a machine stop and tool retract at specified intervals during long roughing operations
7 Comments
al.whatmough
Automatically spitting the opperation could be also usefull to use a differnt tool as well.  I am adding this to future concideration.
You can currently split the opperation into multiple opperations.
A simple split would be using the heights, you could also use containment areas.
You can add the machine stop using Manual NC
al.whatmough
@al.whatmough How would you ever have it split automatically?
On time? Or on where this chips are? Hmm, the software doesn't know that.
I mean I like the idea but not sure on an implentation.
j_cavender
Laurens-3DTechDraw its usually calculated on cut time mastercam does it based on cut time or cut distance.
@j_cavender
Well in roughing that could be possible indeed. In Finishing it would ruin the finish if it just thought well let's retract here since my time is up.
j_cavender
if you read the original post it says in long roughing operations
If you explain it fully in your idea. Instead of stating a demand maybe the questions and reactions wouldn't have had been necessary.
I'm from the Netherlands and we tend to be a very direct and straight forward in our communication but I don't feel your comments are in any constructive. So that's why the reaction above isn't really constructive either.
