Show only
Search instead for
Tool Break Detection needs to be an operation choice
We love the tool break detection to automatically check tool length (e.g. confirm tool did not break) but it needs to be an operation choice, not a tool library choice.
Old thread, but still valid. I noticed in the heidenhain-post that there is a a tool-measure/break command-call in each op! That means the tool (if I edit the post to actually do something with that command) will go to toolprobe twice/op instead of making chips;)
Sure, i can remove those from the post and use manual NC-commands where needed. I cant see any use for having a tool defined with toolbreak-control as default in the library
