The Drawing Mode Needs Updated Please...Refer to OnShape
The Drawing Mode is limited and not very user friendly...
Drawing are a very important part of the mfg process...
Fusion is by far better then other small production cads out there in the means of simulation and modeling layout...
Although adding more features such as the new electronics module is awesome,
We would like to see further refinement in the modules that matter...(The drawing Mode).
I moved from OnShape to F360 a year ago for the simulation capabilities but found that OnShape has a far superior drawing mode in means of adding single parts from an assembly, the ability to edit line weights, etc...
Please look at OnShape for their user-ability and features this would be awesome...
Thank you
8 Comments
This would be an  awesome addition...
Also improved integrated BOM capabilities
manuel.fr
oh yes, i've startet an idea here whitch is only about the bom. maybe you vote that up too.
the bom needs to be fixed with the qty bug and also improved.
Adding single parts from an assembly and the ability to edit line weights - Definitely!
Adding individual parts to the BOM would be a another thing to improve on in the BOM...
Easier editing of the sheet format, and also importing 2D sketches without having to use any workaround.
HughesTooling
Just a heads up on adding single parts to a drawing. You can add to an existing sheet or create a new sheet for a single part or subassembly from the design workspace. Just right click the component and select create drawing then on the dialog select an existing drawing and sheet or create new sheet. Make sure you've saved the 2d drawing at least once!
Mark
@HughesTooling this is true however it also drags the whole model with it to the sheet...
