Hi, I've been using solidworks for two and a half years now and have now switched to fusion 360 so still a little unsure about some things. I've set up this model of a bench with user parameters that change several dimensions when a "master" parameter is changed. I've got to the stage where I want to set up the model for manufacture.
One of the parameters is the thickness of the material and I was wondering if there was anyway I could make the set up in the manufacturing so that the stock size reacted to a change in the thickness parameter like it would in the design page.
I hope that makes sense, thanks!
