Test Idea - Leo Warren
Move it
16 Comments
akhlut
I've been using 123D Beta9 for a while now, and I really love the program.  That being said I'd like to try out Fusion360 but I cannot seem to import any of my files, which is a real downer.  I've invested so much time  and have so many files in 123D!  I'd really appreciate it if I could import them into Fusion360.  Inventor and Inventor fusion have no problem opening them up.
Please, can I haz?
keqingsong
Status changed to: 実装済み
keqingsong
Thanks for the request akhlut! Just to be clear so that I understand, when you try to import a 123D file into Fusion 360 through the dashboard import button, the translators fail to convert the file and import fails?
akhlut
I didn't think I would have to import the files - figured I would be able to simply open them like any other Autodesk file.  I'll have to give the import function a try when I get home.
Thanks for the insight!
akhlut
Nope.  It won't import a file in .123D format.
Not because the translator fails, but because it doesn't list the .123D format as a compatible format.
If you guys could get this working that would be fantastic.
Thanks!
lmlederer
I do not see an option to choose the file extension for 3ds Max (.max) on the Import -> Choose File -> All supported files pull down
menu.  Would you please add that option.
Thank you,
Michelle Lederer
Tags (3)
keqingsong
Thanks for submitting your request! I will keep you posted on the progress of this request as we review with our extended team.
keqingsong
Status changed to: オートデスク今後検討
schneik-adsk
Max data is all polygons and has some challenges converting to solids. We are working on support mesh data directly in Fusion3 60 and are looking at STL, OBJ, and SketchUp models first. Max is interesting but lower in the list of formats. What kind of data do you have in Max that you want to use?
buzzkross
This is a good suggestion and should be easy, we need to get this one done.
buzzkross
This one is harder because MAX makes polygons, rather than solids.   We are working on polygon mesh editing but that will take some work.  This will likely happen later.
Any update on this? I'd love to import 123d files into Fusion 360. Thanks.
michibretz
Community Visitor
I am not too keen on teh fusion thing. tooo onliney for my tast but i got me inventor and I am now lookinga the same issues.
when i go via .stl i do have only problems and cant really touch or manipulate the file ast all.
also reason i got me inventor was to be able to create 2 Drawings from parts which will become a unusabel mess
stianstrips
Whats up with importing 123D Design files to Fusion 360? Has this been implemented?
I just uploaded a design but it doesn't show as any readable file.
What I did was just uplad the file in Fusion 360.
Regards
Stian
keqingsong
123D files can be downloaded as .obj and .stl, and Fusion 360 can now import both as mesh data. We are now working better mesh experience for Fusion 360 as well.
keqingsong
Status changed to: RUG-jp審査通過
