Symbols in Dimension Text
It would be nice to be able to add symbols to dimension text, for example the diameter symbol (Ø) when dimensioning diameters in side views (non-circular geometry), the square symbol (□) and others, without having to resort to copying and pasting from MS Character Map.
The same thing for simple text too.
6 Comments
HughesTooling
For diameter add %%C at the start of the text or hold down the Alt key and enter 0216 on the number pad. %%D gives the ° symbol or enter 0176 while holding the Alt key down.
Mark
WyzeOwl
This page from Autocad might be helpful. it has a list of text symbols and special character references. Not sure if these all work in fusion but if %%c works for diameter conclusion would be that these work here. I have used these special characters in other cad systems that seem to work universally.
 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
HughesTooling
Thanks for posting that link, I could never get the unicode to work before I didn't know you needed the \ character. So to get the square enter \U+25A1
Thanks Mark
PS your link doesn't work first time because there's an extra space at the end, try this.
TrippyLighting
This was posted by Kevin Schneider a while ago.
TimeraAutodesk
Status changed to: オートデスク審査落選
TimeraAutodesk
