STL out
STL out
360 needs some work done on the STL out for 3D printing as well as simulation (though that's never a good way to go). A replication of what's in standard Inventor would be super useful - finer control over tessellation, some sensible presets, and a preview would make it about perfect.
Control over the output from assemblies would be good too.
Not an issue if you're outputting a single STL from an assembly, but some additional options and control when creating separate files for each part would be - in particular when there's multiple references to the same part.
Perhaps with a flag in the file name for multiples when working with separate files to indicate you need multiples and how many (think Bolt_5mm_count2.stl).
Al
5 Comments
schneik-adsk
Status changed to: オートデスク審査落選
We are making progress on an improved STL out. See next comment.
schneik-adsk
Video of WIP on STL export.
schneik-adsk
See: Update 1.7.444 (May 10, 2013)
nice work on this Kev..
123D stl export is easy would be nice to emulate.......now to get reliable output I save to step
then open with 123d to make stl  that are correct.
