Solution for discrepancy between how unit/unit-less User Parameters can be used
@jeff_strater asked what my issue was with creating User Parameters that have units. Please see this unlisted youtube video to see the issue: https://www.youtube.com/watch?v=f8ubuZwZZLE
I have since seen @HughesTooling's workaround to divide a user parameter by 1mm, for example, to make it work in a formula, but this seems like a workaround and is in no way obvious to a user.
I'm not sure what the solution is, but might it be as simple as just ignoring the units when user parameters appear in a field that needs a unitless value (like Qty in the rectangular pattern command)?
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
