When you create a section view in a drawing I would like to see the hatch pattern for a component default to the pattern based on the material assigned in the design. Currently you have to select it. The pattern needs to be changable by the user if the default is not desired.
I would also like to see a small pop up window appear with the definition of the hatch pattern as you move the selection arrow down the list.
Finally I would like to see hatch patterns for wood with both face grain and end grain. I would also like to see a hatch for plywood.
