Smart heal sketches from imported legacy files
Would it possible to have a smart healing of imported cad data? So often there is incompatible line types or small breaks where sketches won't close due to legacy cad files that are corrupted by previous systems. I think a auto trace over feature would be so nice to import vectore or raster type files.
4 Comments
schneik-adsk
Status changed to: Gathering Support
keqingsong
Status changed to: RUG-jp審査通過
Thanks for the idea - however, this is getting archived due to lack of votes. Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers increased support from the community.
erikj7
I think this is something that is badly needed.  I currently have a dxf file that came through just fine with regards to CAM, yet when I want to change the design(so I have a realistic looking model) to extrude cut, it will not let me select that part of the drawing.  I have tried the line across trick, but that's not darkening up either side.
I'll have to trace, or use the text, but since it's on a curve and was warped, neither will come out as exact, as intended.
I have Alibre and the have a Heal feature that works great.  I'd love to see it in Fusion as well, since I think Fusion is awesome!
calebc01
I need this as well.  I get DXFs and need to extrude them all the time.  When line endpoints don't join PERFECTLY, they can't be extruded.
What's truly frustrating is that writing code to heal a DXF contour is stupid simple.  Manually looking at every.  Single.  Endpoint in a large part is impossibly aggravating.
