Sketching on curved surfaces
Ok i know this one must be very tricky but sketching on a non flat surface would be incredible !
I know you can project drawings and models on surfaces but it's time consuming when you have to redraw or modify things (for 3D models, you have to unlink everything after projection and its very hard even after unlinking to change anything).
49 Comments
I'm really after something exactly like Inventor's Wrap to Surface (within Project to Surface) where you can wrap one or more 2D curves or points onto a selected face while preserving the curve length. We already have Project to Closest Point and Project Along a Vector in Fusion; just missing this one!
Example application: projecting a logo onto a complex shape while retaining the correct dimensions.
cekuhnen
interesting tool - has my vote!
Is there a way to flatten a curved face of a body so as to create a pattern for a wrapped part? I am not so concerned with objects with spherical or compound curvature (yet...), but portions of a cylinder or other such shapes.
Abel
haughec
I've added this to our backlog: FUS-15164.
Thanks!
Charles
haughec
Status changed to: 実装予定
MichaelAubry
Hey Cshormann,
We are actually working on putting this functionality into Fusion. The plan right now is to have it in the next few releases.
haughec
Hi Cshormann,
To clarify, when you say "sketch", do you mean using Fusion's existing sketch tools (Line, Rectangle, etc) or are you referring to more "freehand" sketching to sketch character lines, colors, etc to augment a design?
Charles
haughec
Hi Charles,
ideally, both 🙂 But my higher priority is the ability to use the existing sketching tools. I'd rather directly draw a line on a surface, as opposed to drawing on a plane and then projecting. That of course no implies that I can do things with non-planar faces, such as push/pull, extrude, etc. The semantics of modeling operations with non-planar faces / sketches may be a bit more complex, but I think it's still possible to make something that works "as expected" in most cases.
    CS
haughec
Thanks for the quick feedback.  Unfortunately, we don't have an active task to allow sketching on non-planar surfaces with the existing sketch tools.  We are looking into improving sketch projection options (including wrapped projections) which will allow you to project onto non-planar surfaces, but we may not support direct sketching for a while unless we hear more feedback.
Charles
haughec
Seconded / I've wanted to do this a bunch of times.
Dunndor
I would even take Projected sketches on a curved surface.... I wanna know why i cant extrude a godamnned curved face!?
That'd be awesome!
As it is you'd have to patch, offset, and then boundary fill to accomplish the same thing.
Any idea on when this might be added?
laughingcreek
I would also love to be able to draw a poly line that lays on a surface.   This would make so many forms easier to achieve.
cekuhnen
while fusion has a project sketch onto surface
I am curious if it would be possible to draw a sketch right onto a surface.
The reason is so I have more control over curve placement.
the current option to project I think only works mainly for linear directions.
Tags (1)
keqingsong
Status changed to: Gathering Support
odolyte
Hi @cekuhnen, i'll join my former request for the same thing that gathered some votes already : http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/sketching-on-curved-surfaces/idi-p/55...
schneik-adsk
