Sketch - make chamfer tool
I would like to see a tool similar to the fillet tool in the sketch environment but for making chamfers rather than fillets. Sure, you can do it by drawing a line, but it is convenient just like how you don't need to draw an arc with the fillet tool..
4 Comments
XanderLuciano
My $.02 is that it's always better to add fillets and chamfers with 3D options because if you ever decide you don't want a fillet at a certain location, or you want to change some geometry in the sketch, it just works better if you don't have the chamfers and fillets in the sketch. But I still think it should be an option.
jkelindberg
@XanderLuciano:
You are absolutely right of course. But in this specific case the resulting pocket feature would be part of a pattern which I want to have the flexibility of changing. Using then a 3D chamfer would cause a lot of reassignment of edges.
XanderLuciano
@jkelindberg Make one pocket, then do the 3D chamfer, then when you go to pattern it, choose pattern features and select the chamfers as well.
promm
Status changed to: RUG-jp審査通過
Thank you for you idea, due to the amount of higher priority items in the sketch teams backlog this is getting archived.  I do think this a good idea.  Just because an item gets archived doesn't mean it won't be done, it will just be a while before we can evaluate doing it.
Mike Prom
