Show only
Search instead for
I'd like to see a bit more than this. For example - if you could specify multiple "ribs" - and have it generate cross-sectional sketches for each rib - but this could be something as part of the normal, dynamic workflow.
The idea is this:
Say I am building a boat. I'd like to design the hull in 3D - then have Fusion 360 automatically generate the ribs for me. But again, anytime I change the hull, I'd like it to change those ribs. Meanwhile - I may have added manual things to the ribs - like portals, hatches, conduits, etc. Those changes should persist, even if the cross-sectional ribs changes due to changing the hull shape.
In the end - I'd like to export a bunch of (2d) DXFs for rib for manufacturing.
So say for example, you integrated the concept of exporting the sketch from sectional analisys - with the [existing] concpet of a "rib". You could create a "rib" which already was configured to be exported to a sketch (as the rib was modified) - and the rib would modify if/as the sketch was modified. (I don't know if such modifications go two-way now).
Another suggestion covered some "sheet metal" stuff in which the hull itself could be [exported] as a "flattened" 2D tempalte.
