shrinkwrapping mesh to existing bodies
Hi all, I'm currently working on a mesh with some crazy faces on it, and I require additional layers to be as close to the body's profile as possible. Based on the searchs I've done, I don't believe this is yet possible in fusion360- please correct me if I'm wrong.
The idea being you select the faces you need replicated, then click on the 'shrinkwrap' function and it creates a thin mesh of the profile. Editing the amount of displacement from the base body and direction of displacement (either the geometric center, edge, vertex or face) would be fundamental.
Copying and pasting the bodies doesn't quite create the result I'm after as the bodies intersect.
4 Comments
I really want this to be a feature, so many models last week had needed this to cut down time
colin.smith
Status changed to: オートデスク今後検討
colin.smith
Status changed to: RUG-jp審査通過
Archived due to lack of votes.
