Sheet metal DXF export /
this may have been discussed before, but I would find very helpful to have an option to export flat patterns with or without bend lines.
At the moment they do show up and are interpreted by our lasers as cut out paths.
I reckon this option could be  a simple tick box in the preferences such as
"sheet metal flat pattern DXF export - hide bend lines" where the default in unchecked
kind regards,
Remi
2 Comments
shortreportme
Hello!
I hope it will help you to solve at least half of your problem.
https://apps.autodesk.com/FUSION/ru/Detail/Index?id=7634902334100976871&appLang=en&os=Win64
SADIM_cnc1
thanks for the suggestion, this is an interesting partial workaround.
cheers,
