Set Default Font in Text
Give the option to set a default Font you want to use when using the Test command in sketches. Make it a Radio button or an option in Preferences. It's annoying as hell to constantly have to select a font over and over again since the normal convention of using tab to cycle through fields isn't present it takes up even more time.
3 Comments
I think it would be a great improvement to allow uses to change defaults such as font, height, etc when doing TEXT during sketch mode.  It is really annoying to have to change these defaults every time I do text in sketch mode.
Thank you,
Ali
raouldecree
Could also be a idea to keep the last choice of "font and Height" as default.
Thx
Raoul
SGoldthwaite
Remembering last choice would be great.  It's especially annoying to scroll through the long font list every time.
