(semi) automatic spec generation and design review
Before sending models off for prototype or production manufacturing, it's important to do a design review. This is currently an ad-hoc process, but could be at least partially automated in the following way:
1) Import initial spec (text file) or start from scratch
2) At each stage in design, select which feature(s) / attribute(s) you are working on (or create new ones)
3) Associate the design features with the text elements of the spec
4) Before releasing to manufacture, allow user to manually go through spec step-by-step, seeing features highlighted, and approve / reject each one
5) Highlight text and possibly design features that aren't to spec for repair and subsequent re-review
Something like this could save individuals and businesses from expensive and time consuming mistakes, and (if done well), it can generate a product spec that can be used to describe and design future generations of a product.
3 Comments
kb9ydn
This is a really cool idea!  I like this a lot.  You could even use it just for your own reference to keep notes about particular design features.
C|
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
