selection filter and transform mode
selection filter and transform mode should probably be more easily accessible, right now this are buried in the Edit Form tool. selection filter should probably have hotkeys also. Suggestion face= F, edge = E, vertex = V, All = A, Body = B. in modo we do have the "selection filter" expose much like the pic, but I always use hotkeys to switch between the filters. Same with the transform mode I think they shouldn't be buried. Selection options, needs hotkeys(its just quicker to work that way).
2 Comments
kat.ingalls
I work almost exclusively with shortcut keys, too, Son Kim. Great suggestion!
keqingsong
Transform modes now have key combos associated with them. Selection filters do not, but the current UI make's easier to switch between them.
Canvas Selection Windows Key Combinations Mac Key Combinations
Pan Hold Middle Mouse Button Hold Middle Mouse Button
Zoom Roll Middle Mouse Button Roll Middle Mouse Button
Orbit Hold Shift + Hold Middle Mouse Button Hold Shift + Hold Middle Mouse Button
Orbit around point Hold Shift + Click then Hold Middle Mouse Button Hold Shift + Click then Hold Middle Mouse Button
Undo Ctrl + Z Command + Z
Redo Ctrl + Y Command + Y
Copy Ctrl + C Command + C
Paste Ctrl + V Command + V
Cut Ctrl + X Command + X
Note: Set the Default Mouse Control in Preferences to change how you pan, zoom, and orbit with the mouse. Options are:
  • Fusion
  • Alias
  • Inventor
  • SolidWorks
Sculpt Workspace Selection
Grow selection Shift + Up Arrow Shift + Up Arrow
Shrink selection Shift + Down Arrow Shift + Down Arrow
Loop selection Alt + P Control + P
Loop grow selection Alt + O Control + O
Ring selection Alt + L Control + L
Ring grow selection Alt + K Control + K
Ring shrink selection Alt + J Control + J
Previous U Alt + Left Arrow Control + Command + Left Arrow
Next U Alt + Right Arrow Control + Command + Right Arrow
Previous V Alt + Down Arrow Control + Command + Down Arrow
Next V Alt + Up Arrowm Control + Command + Up Arrow
Range selection Alt + M Command + M
Invert selection Alt + N Command + N
Toggle box mode Ctrl + 1 Ctrl + 1
Toggle control frame mode Ctrl + 2 Ctrl + 2
Toggle smooth mode Ctrl + 3 Ctrl + 3
Select edge ring Double-click an edge Double-click an edge
Select face ring Select two faces then double-click a third face Select two faces then double-click a third face
Edit Form Command
Add geometry Alt + Drag Alt + Drag
Add geometry and keep creases Alt + Ctrl + Drag Alt + Ctrl + Drag
