Securing components with screws
Making multiple holes in fusion 360 is a very satisfing function, select your location, decide the type ,size, depth, hit enter and done. I would Like this trick apply to installing multiply screws with the proper animation of righty tighty and lefty loosey. The current animation shows install screws turning anti-clockwise ( should be clock-wise). I would like to select multiply location select my screw type, size (especially if the screws are all the same size) and have them all installed at the same time. Seeing the animation of a screw installed for the first time is amazing, doing that a hundred times and the fun turns into enough already I am done with this. Thanks
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
