Render Iteration Cap
If I have in-canvas rendering turned on, my CPU will always be at 100%. Usually by the 50th iteration everything already looks fine and I don't need more iterations. Sometimes I accidentally forget to turn off in-canvas rendering or I forget to switch back to Model mode and it affects me using other programs or I go do something else while my CPU heats up and stays at 100% for hours. This seems like an easy option to hide in the settings somewhere and it will at least help me feel better about not melting my CPU.
5 Comments
roberto
I often too use the in canvas renderer and would like to have a stop after a certain amount of iterations, or a specific signal to noise ration.
In the new Render window you can select Local render insteaf of Cloud, and set the render to finish at a specific quality level.
The threshold should definitely be a quality level not number of iterations but otherwise agreed
@roambotics_scott Agreed, but the Fusion 360 team needs to revise those quality levels. For us, or rather what I learned from the company I'm with, excellent quality (100%) is still way too noisy for customer presentations or CEO decisions. It Would be nice to have a custom quality level of some sort.
Way with you there @Anonymous
The random ray rendering is great for getting something quick and passable but it seems to take approximately infinite time to converge to something anywhere near publication quality. Throwing darts at a board just isn't an efficient way to achieve good coverage.. maybe a quasi-random approach that covers everything quickly then efficiently fills in in a guaranteed way would be better ?
However it's done, there should be a rendering option that doesn't yield imagines that look like static covered analog TV
colin.smith
Status changed to: RUG-jp審査通過
