Redefine origin/plane/orientation
Hej,
I'm currently running into the issue that I started my Design on a wrong plane.
But there is no option to redefine for example the UP orientation. Only way I know is rotating the Model but than my Sketches are in a different orientation to the Model.
Would be awesome to have an option like you have in the CAM Workspace when you define the stock/model orientation.
Best
Florian
3 Comments
This is (potentially) a great application of the center of mass and moments of inertia.
Centering the basis at the CM [or trivial translation from there] and orienting the axes along the principal moments puts things into a natural coordinate system no matter how a design started or evolved.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
