Project decal consistently across multiple faces
I may have missed something, but I do not seem able to map a decal (or material pattern) in a consistent way across multiple faces. I would like to be able to do this for my following project. There are a number of situations where this ability would be desirable.
Currently, the material pattern / decal is confined to indivdual faces. At the moment, I have compromised by tiling the pattern, but it's not really the effect I wanted.
5 Comments
brucehuang
Now there's a decal command to let you place an image which can across multiple faces in a consistent way. You can have a try.
Thanks for your reply. I have experimented and used the decal tool with success for other models. It works well for a single body/component consisting of multiple faces. However, in this situation, it is not satisfactory.  My project has multiple bodies adjacent to each other, assembled with joints. With a modeller such as Trimble SketchUp, there is an option to align an image, then project & drape across multiple faces and components.
My example requirement for consistent decal across multiple faces:
colin.smith
Thanks for the suggestion @Anonymous.  I'll have the rendering team look at it.
Colin
hutchij
Hi, can you share your model with me. It will help me to prototype your request.
john.hutchinson@autodesk.com
John
don.engel
Hi Colin! I second this request for sure; I am trying to drape a logo across a container model that has raised sections down the side:shipping_container_2019-Mar-18_04-27-35AM-000_CustomizedView37370333230_jpg.jpg
