Portrait and Landscape Drawing Sheets Required
When producing drawings from a design, it would be useful to have have drawing sheets available in Portrait and Landscape orientation, across the range of sheet sizes i.e. A4, A3, A2 etc. Currently only A4 is available in both orientations.
2 Comments
JYZMT
+1 on this. Other sheet sizes are there now (by july 18), but no portrait option? at least that I can find
Also seem to be falling short of basic industry standard requirement here for manufacturing drawings. Im trying to do an exploded view of an assembly that is vertically orientated.
It is possible to draw your title block at the right hand side of the drawing and then rotate your whole drawing 90 to the left. Then if you mount you monitor on its right end you can view the drawing  as it should be. 🙂
