Change multiple Parameters at once
Provide some method for changing more than one parameter in the change parameters at once and then hit an execute or run button to make the changes.
With large or complex components multiple parameters need to be changed but take a significant amount of time to recalculate making it a very slow process.  Making all of the parameter changes at once then allowing it to calculate would be easier and more efficient.
1 Comment
thealucardfromhell
This "set calculation and wait for it to cook" thing is something I've reallllly wanted in any parametric program.
Set a couple of draft operations, hit "Submit" and let F360 crunch away at it.
Right now as it is you need to click, wait a minute, baby sit it, get frustrated by unknown time left, get scared by black bars and "not responding" thinking it crashed, then it snaps back to reality, oop there goes gravity your part is all wrong "error generating" then you misclick and get stuck calculating another minute 😕
I could do with a inaccurate approximate mesh that shows what the generated thing would look like, so you can then record keystrokes and mouse movements to be cached and executed by the software afterwards. I could see a lot of high speed expert "blind" designing.
... at the very least I want the UI to not crash, and to always stay responsive... so I can see time remaining on op, or allow me to cancel it... Please?
