Persistent Measure tool
Hey rock stars!
So I'm working in a sketch where I have 2 Tangent Constrained arcs tied to a single circle. I would like to adjust the distance between these two arcs and ideally use the Measure tool to help nudge them into place.  Rather than take, then a note of it, then click close on the measurement dialogue box, the ability then manipulate my Tangent Constrained arcs and watch the mesurement value adjust acordingly would serve the "Aided Deisgn" in CAD far better.
I'll make a quick vid if that would help illustrate the concept.
Rock on!
4 Comments
kb9ydn
Is there some reason you can't just dimension what you're trying to do directly instead of using the measure tool?  Some sort of visual example would definitely help here.
C|
Richard.EST
I'm pretty sure I don't understand the issue, but if I do, couldn't you just add a driven dimension to the measurement you are looking to observe, and then change the driving dimension to suit, rather than using the measure tool?  Or add a driving dimension to your inspection dimension, then make it driven after setting it to the starting value you desire and then dimension the true driving dimension?
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
