Perpendicular constraint between line and curve
Recently found out that you can't create a perpendicular constraint between a curve or circle and a line in Fusion 360.  You can do it in Inventor but not in Fusion 360.  Really would like to be able to do that.
2 Comments
HughesTooling
For a circle or arc making the line coincident with the centre point will do the same thing. So with the coincident constraint running pick the line then the arc centre.
For splines there is no good workaround yet apart from with Fit Point splines you can add a fit point then make the handle collinear to a line or add a tangent between the handle and an arc.
Also this has been request multiple times going back several years so don't hold your breath.
Mark
aprowe
Community Visitor
how is this not implemented -_-
please Autodesk... implement these old and simple requests
