Pattern work features
Hello Fusion Team,
Would like to be able to path-pattern construction features (work points, work axis).
Thanks!
Kindest regards,
Ludo
3 Comments
keqingsong
Status changed to: 実装済み
Can you provide us some more details on why you would need this? What workflows will this improve?
LMD001
Hello Keqing,
Tried to Pattern Path an Extrude Cut on a 3D spiral, projected to a conical surface, but that did not work and still does not work, I was told back then that a solution was on it's way.
So I figured if I could Path Pattern Workpoints (like in Inventor) I could insert the holes manually.
Since this particular design has been put aside for now, I will wait for the Path Pattern solution.
Thank you for your reply!
Best regards,
Ludo
promm
Status changed to: RUG-jp審査通過
Thank you for idea - this is getting archived due to lack of votes.
