Show only
Search instead for
Tried to Pattern Path an Extrude Cut on a 3D spiral, projected to a conical surface, but that did not work and still does not work, I was told back then that a solution was on it's way.
So I figured if I could Path Pattern Workpoints (like in Inventor) I could insert the holes manually.
Since this particular design has been put aside for now, I will wait for the Path Pattern solution.
