Pattern from Sketch
Pattern from Sketch
Sometimes features have to be placed in large numbers at specific locations. When those features are circular holes, we can already choose to place them on sketch points. But if the feature is more complicated, like a body used for boolean solid operations, this is not possible.
Adding an option "Pattern from Sketch" that allows to select Faces/Bodies/Features/Components and Sketch points to place them at would be extremely useful.
An example application is presented below.
This involves a lot of manual work with the current tools, but a "Pattern from Sketch" feature would make it a very simple task.
2 Comments
felix.uhl
This is already partly implemented by using Move Point to Point. It only requires copying the part for each instance, which is good enough for my usecase.
abulfetouh_1987
I was looking for such feature, it would be very helpful especially with more complex Booleans, it can save time
