parent object highlight when selecting elements of a part
as you can see LMB is great to select what is under your courser.
But the problem is the vertex points as well as edges are highlighted but I do not know to
which object (here the two cubes) each belongs to.
Thus I think it would be beneficial if Fusion can highlight the object I would select an element from
5 Comments
So agreed!
Minus that and you've got a list of identical objects and no way beyond clairvoyance to tell which is which.
cekuhnen
yep - thats the problem with the current implementation. when it is a single object it works great.
with multiple objects not really.
haughec
I agree that we should provide more information on selection results.  I've logged FUS-15793 to track this internally.
Charles
haughec
Status changed to: オートデスク審査落選
cekuhnen
Great!
