Using parameters in a design is one of the most useful things that you can do when sketching. You can change parameters and the sketch will adapt accordingly. That's good and I'm thankful for this functionality. One parameter can also be dependent on previously entered parameters by use of formulas.
But: I cannot swap the order of parameters at all. This is necessary when editing formulas that reference parameters that are defined earlier ot later. Actually, this should be possible using a drag&drop.
I can very well understand that a parameter which is used in a parameter's formula that is defined later cannot be swapped to be defined after it is being used. But the others should be changeable.
In the parameter list I want to swap parameter _second and _third and then change _third to be calculated from _second.
