Oculus Rift
Oculus Rift
This is a crazy idea.
I got one Oculus Rift DK2.
I would like to interface this stereoscopic vr display to analyze my models created in Fusion360.
Probably you know that the Oculus Rift DK2 works as a second monitor. You could switch the F360 framebuffer to the OR input to get a stereoscopic output.
Imagine to design a cockpit or whatever object you want and evaluate it with a vr headset.
regards
5 Comments
haughec
Hristovag
Is there a way to design an actual model with the Oculus? I'm having a hard time with this.
Thank you,
Gery
Seeing the CV1 specs (occulus touch for movements) as well as the amount of pre-orders, I'd say supporting this type of hardware would be a huge hit and would make working with Fusion360 even more fun!!!   https://developer.oculus.com/
http://www.theverge.com/2015/9/25/9393097/oculus-rift-medium-paint-virtual-reality-video  shows how to control the viewport.
Hi Gabriele,
We worked on a solution for this 🙂
Check out ENTiTi at www.wakingapp.com or use our new Plugin for Fusion 360:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=2506286817804633532&appLang=en&os=Win64
With this you can seamlessly check out your models in AR or VR in just a few minutes.
Let me know what you think about it! 🙂
thburn
it would be great if there is a much simpler approach like a simple red-cyan view to see the objects in real 3D.
