NPT Threads
NPT Threads
Can you please add NPT to the threads generator. This is a standard thread type and not in the thread generator currently. Thank you
21 Comments
jodom4
Thanks for your idea,
This idea has been accepted and is currently in development. We're testing it now for bugs, and although I can't give you a definite timeline, it is in the queue for release. Please follow this thread for updates: https://forums.autodesk.com/t5/fusion-360-ideastation/npt-pipe-threads/idc-p/8174677/highlight/true#...
Swarfmaker
The need for a truly comprehensive set of international (worldwide) threads is long overdue. If this task is too great then the ability to locally store custom threads is of paramount importance. This topic keeps arising so please give it some attention.
miked6HT2T
I have looked at attempting to create custom thread sizes by editing a thread library using an HTML editor.  I chickened out fearing I would break something.  How about adding a thread library editor that uses existing standards for thread designs?
gmdimarzio88
Autodesk is an american company correct? How can you not have NPT threads in this? Baffling!
ballsopECAM
Used in my industry all the time .... Would be great to have it ...
is this done yet?
gmdimarzio88
Anyone have a work around for threadmilling NPT threads currently?
ballsopECAM
I have a potential work around to make an NPT Pipe Tap in Manufacturing module.... For this example I have mad my demo around a 3/8" NPT Pipe Thread.... I made a sketch which had a .675" Diameter circle at X0Y0Z0 I then entered into the Patch Module and extruded a surface off of the circle with a 1.7899° Tapered wall .550" Deep. Enter the Manufacture module (Under 2D select BORE) and then select a 3/8" Flat endmill (or set it to whatever diameter your thread tool will be) The pitch on a 3/8" NPT thread is 18 TPI .... so enter 1/18 in the pitch step box. If you want multiple step overs to reach full thread depth then tick multiple passes and enter 3 with .015" step over per pass. You will need to play with the stock values + or - to get your pipe plug to sit flush on the work piece but i think this might work for your needs until the guru's get NPT added to the list of threads... I have a .f3d file with the example in it i could post but i don't see where i can attach the file ! Let me know if you want the file or need help with what I have proposed.... Brain
rishabh.bisht
Glad to share that we have added this functionality with the March 2019 Release. You can now create tapered threads in the Hole command.
External thread are still missing
Do they work in cam with a thread mill?
TimeraAutodesk
I see that this has been implemented according to this topic, however in Fusion, I do not see NPT as an option. Is it named something else? Or maybe its using a European naming that is the same as NPT for us in the States?
Disregard, I was looking under Threads instead of using the Hole tool.
rishabh.bisht
@Anonymous Currently, NPT threads are only present under the Hole command.
Change the Hole Tap Type to "Taper Tapped" and you should see the NPT  option in Thread Type dropdown.
gumert
Observer
@rishabh.bisht I'm struggling to get the threads created with the hole tool to be modeled (I don't see the modeled/cosmetic option in the hole tool and changing threads:modeled in document settings does not appear to be doing anything.
Am I missing something? Thanks!
rishabh.bisht
Hey @gumert , thanks for reaching out!
Tapered threads are only available in cosmetic mode right now. That's why you don't see the option to toggle between cosmetic and modelled thread when you switch to  "Taper Tapped" option.
gumert
Observer
Got it, thanks for the follow up.
npt only added to hole tool.  need to be able to add external threads.   What's the point of making a threaded hole if I can't make a threaded part to put into the hole?   Is this still being worked on?   Any updates on time line would be nice.
Hello fellow forum Peoples....
External NPT Threads.... Here is a suggestion.....
If you modify the external thread surface and add 1.79° / side draft onto it and then Press/Pull the diameter to the proper size of the male thread feature that you want.... This is the standard draft angle for NPT threads.
Then you can use the 2D Thread function to cut the tapered surface you require.... Set your pitch to to match the thread you are cutting here..... example : 1/11.5 for 11.5  TPI ..... Lots of adjustment to the machining parameters and you will need to figure out the diameter of your thread mill tool to work properly.... But i have done this many times and it works well... I use the "Multiple Passes" option and step into the thread 2 or 3 times to get a good finish on your part....Adjust your plane at the top to be about .050" above the top of your part so you get a good thread start.... Set the bottom plane according to the tool you are using so you don't smash into the bottom surf also.....
Hope this helps
But the pressing question is why weren't tapered threads part of the
threads tool from the beginning? These threads are included in every
thread wizard I've used previously, including inventor.
I don't want to spend time making tapered threads from scratch when it
should be basic functionality built in from the beginning.
