I am used to work with Inventor 2009 and recently switched to Autodesk Fusion.
I used to provide my suppliers with DXF files (made form drawings) which they can use directly to drive their machines. This worked perfectly.
Fusion on the other hand doesn't have the possibility of DXF output from a drawing. Yes, you can do this from a sketch but 3d models are often much more complicated than just a simple sketch. So this is no appropriate solution.
My suppliers cannot work with the DWG 2013 output that Fusion gives...
If you ask me Fusion should provide the possibility to output a drawing to DXF.
