Mousewheel to cycle through selectable points, lines and objects
Sometimes I want to select a point, but it is close to points from other, nearby shapes. I can zoom way in and click my point, but it takes too long to keep doing.
I suggest making it so that scrollong in the mouse wheel will cycle through points, lines, faces and what not that are within a user specified radius of distance to the thing the mouse is currently pointing to.
In this image the mouse is pointing at the line belonging to the grey shape. I want the line belonging to the brown shape. One mouse wheel "click" in either direction should switch the mouse selection to the brown shape's line.
I realize the example isn't fantastic as you could simply move the mouse to the brown shape's line, away from the grey shape, but see beyond the example.
Also the object that "has" the line I want should be clearly highlighted as well - so if I scroll the mouse wheel and get the the brown shape's line instead, the entire brown shape should become blue so I know that the line I can now select by left clicking is, in fact, belonging to the brown shape.
4 Comments
In SolidEdge, if you hover your mouse it will show an elipsis. Then if you click, it shows a menu that contains all entities that are under your mouse. It's a really nice way to select stuff if working in a complex part.
cekuhnen
actually when you press and hold the lmb you will see a list menu
but it is not ideal as it does not highlight what vertex from what object you can select like here
Alt+ LMB like CATIA or TAB when cursor positioning on ojects like Revit.
colin.smith
Status changed to: RUG-jp審査通過
@Anonymous
Holding down the mouse button will bring up the pick list.
