More control over cutting order needed
Hello peeps!
I frequently have this problem. I have to cut like hundreds of little circles using Contour in "half hard" steel. With multiple depths, gradual slope angle and all it's a long run. Many times I leave the machine run and go home.
The next day I usually see a broken .031 ball mill with an incomplete cut done.
What I've done over the years is duplicate the cut, reselect the ones after which the tool broke and run it again.
What I'd like to see is more control over the order the features are cut, like reverse order, random would be good come to think also, start and end selection, or something similar would help. The Drill cycle gives more control but I'd like tons more.
I tried Order By Islands but that didn't do what I expected. I thought it would cut each feature to the first Multiple Depth stepdown, move on to all features, then the next stepdown, etc. I have to experiment to see what it actually does.
ps. Today I had a Christmas Miracle. I came in and both the .062 ball and the .032 ball survived the 13 hour run...go figure.
3 Comments
My interest in this request lies in the "Reverse Order" option. Quite often, my toolpaths consist of a 2D Contour that has been duplicated a few times; 1 rough, 1 finish, and then a deburr. On complex or multiple parts being run, having the option to reverse the "Preserve Order" would be very helpful, rather than deselecting everything and selecting it in the order you wish.
I'm uncertain what benefit would be brought by a "Random Order" option....
fishtruk
I'm just spitballing with that. Anything other than reselecting a few hundred little features would help. Even with my SSD and a fast computer the selection slows down after the first hundred.
It's not easier being in between my 2 cataract surgeries if you know what I mean.
I'm asking a lot but having a "start cut here" would help.  Or Random with the option of Try Another Random Order perhaps...
Guess I have a rather obscure problem.
daniel_lyall
It makes sense @fishtruk if we could have a window selected as well it would be good, I have turned work down over having to do a massive selection, 1000 holes
