I've been working on a project for a couple of days now and my assembly is getting bigger and bigger - with this an increasing amount of hardware is building up on the component list - I have over 200 bolts and it is becoming tricky to manage what components are actually needed - so I propose a way to create a folder in the component list on the left - much like what happens when you create a view I think that you should be able to create a folder of components, this will also allow the user to quickly turn off unnecessary components such as nuts and bolts; this also allows the users with lower-end computers to better scrub through there design without major optimisation. The user should be able to just 'Drag and Drop' the components into and out of the folder.
