Modify Face & Variables Fillet
While working under "model" I wish I could change the individual faces of the model
with an easy and immediate ...
Would also have the possibility of having a variable radius fillets along the same line
Fabio
8 Comments
keqingsong
Thanks for the suggestion Fabio, will take this into consideration!
schneik-adsk
Status changed to: 実装済み
For the select a face and drag... Would you find to much an interruption to your flow if: you select a face, it highlights an a small glyph appeared on the face. If you click the glyph and drag then the edit face command (i.e. Press pull for solids or edit rom for tsplines) automatically started?
Having the ability to score critical points, and eventually move along the edge.
Being able to pull the glyph also visually check the effect and give the OK, or give the exact value numerically and give the OK!
garin
Variable fillet has been added to Fusion 360. In the regular Fillet command once you select an edge you can chose to make it a variable fillet.
Thank you, I got to appreciate the work you have done!
What would make sense is to have full SRT transformation abilities for each solid face, like you do in Scultp mode.
colin.smith
