mirror without joining
It'd be great if there were an option to mirror an object about a plane without automatically joining both images into a single body.
For some reason I'm finding that even if I add a construction plane on the mirroring plane and try to split along that, Fusion just won't comply and not having to do that gymnastics in the first place would save time even if that'd work.
3 Comments
Oceanconcepts
Does using the Dissolve command on the Mirror, or Make Independent on one of the mirrored objects, solve the issue?
Nope that definitely doesn't work because when I mirror it immedately creates a single body so neither option is even availiable.
keqingsong
Status changed to: RUG-jp審査通過
