I was hoping that there would be a way to connect this with the Microsoft Hololens, I think that by utilizing this we would even be able to do stuff like 'sketch and extrude a shape, then grab and hold that shape in place with one hand while the other one turns into a slicing tool to cut it right in half, there is so much that can be done with this, please help support the idea and share this / like it ::-)
If you have any ideas that you believe would fit this project in terms of functionality between the hololens and fusion/inventor/maya then please do share 🙂
This is what I have come up with so far:
** Functionality List:
- Voice assign tools to left/right hand.
- Hold objects in place, rotate, move with hand, scale with both hands.
- Slice tool which allows to slice through object anywhere. (to an extent possibly)
- hand mold (grab objects and when you squeeze (close you're fist) and rotate and pull the object will form like putty or clay does
- voice command : insert background image for sketching (inserts image of choice)
