Mesh Palette
Mesh Palette
Hi there
The brush size in Select /  Mesh Palette should always go down to one face (triangle) independent of size or  number? of elements.
You may implement it also a  by a checkbox:  Select one Face. or adapt the limitation
Until a certain size (or number?) of faces this is already possible. However  if facets are smaller the brush selects always more than one:
Advantage:
In case you select a triangle you can separate this (Modify / separate) then  switch to Model / Mesh to Brep.
Further constructions can now be done easily  by creating a  plane through the 3 corner points and create a sketch respectively.
This is helpful  to  construct holes, pivots etc.  in CT scans of bones for instance.
2 Comments
The brush size should have 3 Options:
1. fixed brush size independent of zoom level e.g. in mm
2. brush size adjusting to zoom level i.e., always the same size on the screen hence down to one / a few faces in maxmium zoom level
3. single face picker & un-picker
JPS_2000
Indeed just adding a face pick/ unpick selection seems very convenient. It depends what is easiest to implement.
