Manually enter camera position and zoom
I sometimes make two (or more) designs of a component, and I want to put them in a presentation to compare them. It's pretty difficult to get the view exactly the same in two different windows. The workaround is to make a new design where all the components are added and use the light bulb to turn them on and off.
Now, the problem is if you want to compare simulation results...
So, how about if you can make an option to set the view camera properties?
1 Comment
I VERY much need the same thing!  I need to render a image of a product in a exact manor (and no named views does not work well for this)
I would need a camera input box so I can manually input the exact location, direction, and zoom and have it reliably be reproducible between projects. I currently have to export this to another application which wastes time. (Export, re-texture, lighting etc. when a in app render in Fusion is good enough.)  This diminishes the use of Fusion for us and makes portions of Fusion useless to us, ie texturing, lighting, and the renderer (including the cloud renderer which is bad enough you need credits for but can't even get the shot we need for the extra $)
