Layers in Sketches
Layers in Sketches
Just as assemblies can be comprised of sub-assemblies and sub-sub assemblies, and components can be comprise of sub-components and sub-sub components that can have relations between on another, I would like sketches to be comprised of sub-sketches and sub-sub sketches, and I would like to be able to define relations (alignments, positions, dimensions) between objects in each layer, and the layers themselves.  Layers be a  2-dimensional spatial representation (literally a layer) or a collection of sketch objects.
I am thinking of somethign like the equivalent of hierarchical Layers in Illustrator.
For a few example, I'd like to place all the dimensions for a sketch in a dimensions layer, and all the constraints in a constraints layer, and be able to turn them on and off (visually and functionally).
-jamie
14 Comments
schneik-adsk
Status changed to: Gathering Support
kb9ydn
I would separate this into at least two different functionalities.  One is to be able to toggle on and off the display of dimensions and constraints (I thought this was already in the works actually).  The other is to be able to separate sketch entities into groups.  In Solidworks they call these "blocks".  Each block is essentially its own self contained sketch with it's own local dimensions and constraints.  Blocks are also hierarchical and can be nested.
C|
I've always been convinced this is how multiple sketches in the same plane should be handled rather than creating new sketches.
schneik-adsk
Status changed to: 実装済み
TimeraAutodesk
Status changed to: RUG-jp審査通過
Archiving due to lack of comments as requested.
Dislike.
12 votes and no request for specific comments (just comments, in general)
kb9ydn
I think since the OP made the initial request it's up to him to follow up with additional information if requested.
But this does seem pretty straightforward so I'm not sure what additional comments would be needed.  And yeah, it would bave been better if AD had probed a little more instead of simply requesting comments.   Smiley Frustrated
C|
Hitting the «comments requested» button is like putting a question mark in. Without a question, it doesn't mean much 🙂
I just ran across a situation where layers would be very helpful, was disappointed they were missing.
Cheers!
Why is this archived at 12 votes ?!?
iSuat
maybe this makes a little easier
I also think this would be useful.  The case I'm working with is I'm creating a floor plan in Sketch.  I'd like to have one layer have the rooms, another have the doors, and a third have the windows.  That way I can toggle on these layers individually and see how everything pieces together.  Is there already a recommended workflow for handling this type of thing?
The easy thing to do would just be to make and label three co-planar sketches for rooms, doors, and windows [for the record - that that is so trivial makes this UI sugar not getting built out much more annoying to me]
As you see it is now Feb. 2020. This issue about the lack of layers in sketches still remains.
Back in 2016 a community manager archived this discussion/thread but that doesn't mean that there aren't folks like me wanting and waiting for a change.
The first thing I did was "vote" for this suggestion and as you know that vote wasn't counted. I wonder how many others have tried to vote.
Dear Community Manager,
Please initiate the change to Fusion 360 sketches and incorporate layers, so many of us would be happy!
You don't have to open this discussion or worry about votes or whether it should be archived, just get layers into our sketches!
Stephen
